metalman2
- Dec 23, 2013
i just ordered new filters and 1 new fuel pump. I figure I'll switch the pumps 1 at a time to see if I have a weak one. Hopefully this will fix the issue. If not I might start thinking stater or it becoming a back up sled!!
One other thing, this only happens between 7500 and 8000 rpm. Closer to a steady 8000 rpms.
metalman2
- Dec 23, 2013
Update!! I just got back from a couple 2 mile full throttle rips across the lake and all seems fine once again.... I decided to just replace the fuel filters to help determine what fixed it and that was all the farther i needed to go.... Now what do i do with the new fuel pump??? I think it's going into my parts for problems box.. Let me know if this helps anyone. Steve
Good you found it.
