Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I thought about that too but how would you see it? I put one so I could see it next to the ignition switch. It would be useless where it is.FYI: I believe people used to put LED's in the wiring so they could tell it the starter solenoid ever stuck on. I was going to do it at one point but never got round to it.
riverbilly
- Nov 2, 2025
- River valley
- 2004 rs venture 1000
Mine was hidden under that ignition. I dont know. I'm just trying to figure out why was this wire tampered withI thought about that too but how would you see it? I put one so I could see it next to the ignition switch. It would be useless where it is.
riverbilly
- Nov 2, 2025
- River valley
I would assume. Ypu would have full continuity from battery ground or ground to frame to ground boxes? Right? I'm not good in electrical. I just want to fix this issue so I can go fishing this season. I got it for a good deal so if she continues giving me problems ill make my money back no problem. But I like the machine.All the way to the battery post? That's likely your problem. Just be sure it is a ground block as all the wires going into it should be black. Maybe try running a wire from the battery - to it and see if stuff start working again.
RobX-1
- Coldwater, OH
Based off your other posts and now knowing you also have a chewed up speedo sensor, its quite possible that connection is shorting things out. Just a thought as it would appear you have multiple electrical issues where it may not be a single culprit.
riverbilly
- Nov 2, 2025
- River valley
Yea thats what im thinking. Also if I disconnect the speedo sensor. Will it do anything.Based off your other posts and now knowing you also have a chewed up speedo sensor, its quite possible that connection is shorting things out. Just a thought as it would appear you have multiple electrical issues where it may not be a single culprit.
RobX-1
- Coldwater, OH
I suspect it will throw a code but if the chewed up wires within the speed sensor were causing the short, at least you could re-test your ground continuity with it disconnected.
riverbilly
- Nov 2, 2025
- River valley
Makes senseI suspect it will throw a code but if the chewed up wires within the speed sensor were causing the short, at least you could re-test your ground continuity with it disconnected.
riverbilly
- Nov 2, 2025
- River valley
Update. So I disconnected the speed sensor. I now can control my hand warmer on the screen. But the thumb warmer remain undisclosed. Also. If a bad speed sensor i mean bad. Chewed up by shaft. If its bad would it trigger tors even when system is bypassed ?
riverbilly
- Nov 2, 2025
- River valley
Wires were chewed up. The end of shaft chewed up the sensor bad. Bad bearing. Was resting and rotating on sensor.Makes sense
riverbilly
- Nov 2, 2025
- River valley
Another update. Played with the ground block again by the ignition panel. And got continuity. Now my tors is gone fuel guage is aluminating. And can control
Hand warmer.
Hand warmer.
- 7K
