05 RX1 rear suspension numbers
dracutaco
dracut ma/bethlehem nh(weekends)
rear heat exchange #8et-rhecr-kt-00
ra protector kit #8fu-raprt-kt-00
clutch shim kit #8es-slidr-kt-00
rubber idle wheels #8es-47310-40-00
06 pivot arm #8ft-47331-00-00
rails #8fu-w4741-00-00
rear shock #8fu-47480-00-00
misc collars,bushing,shafts for a grand total of $1796.06 of which i am responsible for $41.90 for rear heat exchange.
this may have taken 8 months but i recieved my parts today and am once again a very happy yamaha owner. Thanks yamaha!
reinforcement kit
the new rails did not come with the reinforcements however they should be released around the 22nd of nov, but the pivot arm is the same as the apex and does have grease fittings. as far as the reinforcement kit i am making my own up and will post pictures next week, if you have seen the apex the rail only has a bar placed inside the grove of the rail. the wheels they replaced with are also the same as the apex but the bearings are still not replaceable.
