05candyredrx1
I have a '05 Vector that has a problem with the gauge pod being blank until the machine warms up. All other electrical is fine. Any ideas?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Hold the thumb warmer control down and turn the key on. Continue holding it down for several seconds (I think 10) Does the gauge and lights come on?
There's a relay that powers them on located below the reverse lever on the back side of the plastic. It may have a week coil or a moisture issue and needs replaced.
twomorestrokes
Mine's done that before on super cold mornings. Let it idle and it should come on.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
I second that!
05candyredrx1
gauges
It was 27 degrees this morning and it came right on without delay. When it was 10 degrees the gauge pod was blank, but the headlights were on. The gauge came back to life after warm up. Just thought it was odd. My RX1 does not do this at all. Thanks guys!
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Pull the relay out and check it for moisture. The contact for the gauge may be sticking (froze). You should be able to pull the cover to inspect it. I've seen several relay issues over the years and most of the the time the problem is moisture.
05candyredrx1
gauge
Which relay? There are two right?
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I believe the outer relay is the one your looking for. The middle relay is for the headlight and the inner one I'm not sure of (carb heater?) I think they are all interchangeable.
MadMax
Mine and others I've talked to have done that in cold weather from day one............. No biggie.. First time it happened to me I went ooooops.. Now I'm use to it.. MM.
twomorestrokes
Yup. Like MM says, mine did it first back in '04 when brand new and it has been talked about on this forum for years. It's not going to cause any issues.
05candyredrx1
gages
Yeah, I have bigger things to work on.....not big issue...just curious. Thanks
twomorestrokes
Just finishing my first real maintenance on my '05. Had the skid out for the first time and all I found wrong were those two inner idlers. that and the battery finally kicked it. I'm ready for a good ride!
05candyredrx1 said:I have a '05 Vector that has a problem with the gauge pod being blank until the machine warms up. All other electrical is fine. Any ideas?
This is normal when it is really cold. Warms up and comes on. Nothing is wrong electrically.
