northbaydave
- Dec 6, 2011
I have owned my 06 Apex Gt for 4 years now and had no problems so far, until last season when I threw a stud and punctured the front heat exchanger. I have a buddy who owns a welding shop so we buttoned up that problem right away. Ever since then I can't keep the coolant in it? As soon as im up to temp, the overflow fills up then spills on the ground? I thought vapour lock, so I raised the nose almost vertical 3 times in a row while up to temperature and im still having the same problem!!! Anyone have anything for me?
yamascoot
- Feb 18, 2011
overheating
it usually helps to raise the rear of the sled. I think there is a bleed off fitting somewhere on the rear heat exchanger, or on the crossover pipe between your side exchangers that are under the running boards
haymel69
- Jan 25, 2024
- Wisconsin
- Yamaha Apex
What did you ever figure out? And yes i know this thread is 13 years old. Lol
RobX-1
- Coldwater, OH
More than likely, the OP never performed the proper bleed procedure and still had air trapped in the system.
Even though I use this to fill my coolant:
I still had to perform this as there was still some air in system as evident when unloosening the bled screw:
