I have a hand warmer wire problem needs fix see the yellow wire I get power too that and black red one I get power too that to but not a lot and the one I have in my hand I get the same as the black red one with yellow small amount and the one my had black no power . They connect too my hand Warmers on my bars that work wen I put ground and power from my batt direct too the plugs on the bars and the thump Warmers work good please help me just hope someone can help me feel free to text me at 6037020989 my name is rob
You have the RPMs up when checking?? those will not get full voltage until the RPMs are at a certain point. Rev it up to just below engagement.
Owe and they connect to my hand Warmers on my bars that work wen I put the 2 wires ground and power and my thump Warmers work fine
yes I rev up but still hot hi like the yellow on didYou have the RPMs up when checking?? those will not get full voltage until the RPMs are at a certain point. Rev it up to just below engagement.
Did you check the resistance on each side and see if there is a problem with the grips? I know the original 06 grips were wired in series and it they would not heat properly... contact Rockmeister... he know the wiring inside and out. You can text him 260.710.7623
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Exactly! My 06 was the same way. Heat would be only decent once rpm's were up,for a while, the be all over the place. I switched to Rocks setup, and it is amazing the difference
