everything is going well, call me when you get a chance. jeff 1-414-698-6611
dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
Intercooler cover
CPR,
Are you going to develop a cover for the intercooler to close up the opening in the hood where the stock air box cover once was?
CPR,
yes, there will be a cover in our kit. jeff
andgjerd.
- Oct 8, 2005
Rs kit?
Will you made these kit for RS modells to?
they are in stock now for rs and rx1s. jeff
When are we going to see Apex's kits? Need 3 of them, have customers waiting to decide on what system to go with. Sledding season is coming up real fast.
soonest apex kits will be released is mid to end dec. we want to make sure our tuning is spot on before any are released. jeff
KbxSrx
Looks awesome Jeff, what do you think of the side mount that Boondockers are doing? Not your 'style' or for what reason do you prefer your way? The only reason I like theirs, is not changing fuel tank really.
our apex fuel tank will have close to stock capacity because we get rid of the internal fuel pump and the huge cutaway that mounts it. therefore our cutaway for the heat shield should end up being the same volume. as for the boondocker, i did things the way i did for a reason, knowing what i know now, i would still do things the same way for reasons that i will keep to myself. jeff
noob
SIMONS CPR said:our apex fuel tank will have close to stock capacity because we get rid of the internal fuel pump and the huge cutaway that mounts it. therefore our cutaway for the heat shield should end up being the same volume. as for the boondocker, i did things the way i did for a reason, knowing what i know now, i would still do things the same way for reasons that i will keep to myself. jeff
Jeff, minds are going to be racing now with these reasons your keeping to yourself.lol what's the cost of the simons cpr turbo. I might be getting an apex, looking into it. I'm sure you posted it earlier, i'm too lazy to check it out. noob
trx-1noob, 5000.00 for apex system. jeff
Thrusted Vector
Jeff,how goes the turbo project?Linc
we are working with it and hope to release it sometime in jan. jeff
Do you install?
Do you guys do installations there? How much does that add to the cost? I may want to drop my GT off there this spring.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Jeff, how are the Apex turbos coming?
