I have an '06 apex that recently started stalling out at idle once it's warmed up. When you start the engine form cold it'll idle as normal... just seems to start happening once the engine is up to temperature. The machine is stock. I've searched this issue on here and have seen how it's happened to others but the thread I was reading never did come up with a solution... just described the same issue I'm having and a lot of ideas about what to try that never worked out. Just wondering if anyone's figured it out?
heelingcowboy1
Does it do it all the time after warm up or just sometimes?? Also does it sound like it looses a cylinder when it starts to die?? Any error codes??
YamerHammer
If I had to guess I would say exaust donuts. Have you tryed the old rag over the exaust tips to test if they are good?
The exhaust donuts are ok.... replaced them last winter.
I probably should've mentioned the sled runs as usual once going, no power loss or any error codes showing. Also, it doesn't always stall out every time but definately most of the time... say 8 out of 10.
