06 attak snowtrackers
myrodman
Age
67
NEW BOSTON.ILLINOIS
06 attak
05 warrior
Did everyone running snowtrackers set the toe to 0 or run a slightly toe out measurement What other changes did you do? My rubber ski pads are shimmed-should I remove the shim?
Toe should be set at 0..
Remove the shim.
Set up sled so there’s minimal ski pressure, back off front spring preload, rear suspension front strap should be at its longest setting.
