APEXMAN
Hi all u yama dudes the summer is coming on us fast and then it will be fall and then yessssssssssss it will be winter again ( yeee-hawww) . My question is that i have an 03 rx-1 and i was wondering if my original handle bars 06 from my apex would fit and are they wired up the same .. Has anyone tryed to do this before ....... btw the reason for changing them on my 03 is that i love the hooks on the ends and what the hell they are free lols ................ thxs
steve
steve
APEXMAN
wow cant belive anybody hasen"t tried this one before
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Great ?, I am amazed at no experienced reply's.
Sorry can't help with details
Yamadoo
Yamadoo
BigDog05
Go to this post.
http://www.ty4stroke.com/viewtopic.php? ... light=bars
I don't know for sure but I'm guessing the 03 is the same as the 05.
I have 06 bars on my 05 the past 2 seasons. No problem. You will have to cut the ends off the wires on the 06 bars. They are different than the 05 bars. Take one wire from each grip and hook together. Take the remaining wire from the left grip and hook to the black wire coming up the steering column, take the remaining wire from the right grip and hook to the yellow/black wire coming up the steering column. This is in series like your old grips. They will get very hot this way and you will use 1/2 setting or less.
Or you could hook them in parallel like the 06 bars are stock. Hook one wire from each grip together, hook the other wire from each grip together. Hook one pair of wires to the black wire coming up the column, and the other pair of wires to the yellow/black wire coming up the steering column. They do not get as hot this way. Had them that way the first season and they were ok but not as hot as my stock 05 grips.
If I'm correct, your 03 grips do not return to previous setting like my 05 does after the sled is shut off and restarted. Therefore you will have to remember to turn these down every time you restart the sled, if hooked in series.
APEXMAN
bars
I cant belive that i have only got 1 reply come on guys help help me out here ....... thxs steve ..
