RXW10
After starting it goes to 1400rpm, right where it's supposed to be. the problem is when I blip the throttle. The first time I blip it, it bogs and hesitates. If I blip it again the rpm's shoot above 2000 and then settle at 2000. It will not go back to 1400. Any suggestions? Thanks in advance!
RXW10
Almost forgot, it's brand new....Zero miles!
MadMax
#1, Do you let it warm up until the red dash light goes out???? If not. then the onboard computer won't let it rev real high... #2, It's new....... Let her break-in some. You will love the motor. MM.
RXW10
Yes, the red light goes out indicating that it has warmed up. The problem is that after it warms up and idles at 1400rpm (where it is supposed to), it will stick and idle at 2000rpm. Sometimes higher. It should fall back to 1400rpm. Thanks.
DaJudge
Try to wait until the snow starts flying again, yea I know. You will end up changing spark plugs. These motors do not like being started and shut off without being totally warmed up. I am surprised your dealer didnt tell you that.
sledheadgeorge
let it warm up good and make sure the choke is off.
