Rollover help
mattison
RI
2010 RS Vector, 2011 Apex SE, 2016 Apex LE
So backing up I went off the edge of rhe trail and rolled over. I couldn't get to the kill switch to shut it off but it didd eventually stall. After getting it upright again I let it sit for a few minutes to let the oil settle where its supposed to. Sled started right up but LO-OP won't go away. After letting it sit for an hour, it still won't go. What else do I need to do. Airbox is clean also. Rollover was on the right side.
Sounds like you need to prime the oil pump. Do a search and you should be able to come up with a post that describes how to do it.
