APEXMTSEO7
- Apr 12, 2016
- Norther BC
- 09 Apex MTX
Having read many threads about the bolt breaking that holds the Apex reverse gear sprocket assembly on the drive shaft I wonder if the 2011 and up reverse design with the extra bearing in the cover is stronger. Is it a more reliable set up than the 06 to 10 design ?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
All the broken bolts I have seen are on the nytro. Never have I seen a broken one on apex.
APEXMTSEO7
- Apr 12, 2016
- Norther BC
- 09 Apex MTX
APEXMTSEO7
- Apr 12, 2016
- Norther BC
- 09 Apex MTX
I forgot to mention that it was about the Apex chaincases which I was wondering about in my initial post.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
if you order a new bolt from yamaha you will get the up-dated bolt. if you need the part number i can post it for you.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
X2 Apex chain case have never had a problem with bolts breaking, but Nytro's yes. The Apex has a way stronger bolt and different design than Nytro also.All the broken bolts I have seen are on the nytro. Never have I seen a broken one on apex.
APEXMTSEO7
- Apr 12, 2016
- Norther BC
- 09 Apex MTX
Are you referring to the 06 to 10 reverse chaincase or 11 to 17 style with the extra bearing in the case cover?X2 Apex chain case have never had a problem with bolts breaking, but Nytro's yes. The Apex has a way stronger bolt and different design than Nytro also.
budman 1000
- Jan 22, 2010
- Saskatchewan
Both actually , they have a hardened steel bolt and have never heard of one breaking, the Nytro which is the problem bolt is a soft piece crap bolt and just about everyone broke and was updated to a slightly beefed up bolt, but still not even close to strength like the bolt in all the Apex modelsAre you referring to the 06 to 10 reverse chaincase or 11 to 17 style with the extra bearing in the case cover?
