thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
when i open up my 2007 apex gt wide open on a straight then let off fully for a stop sign it shoots flames out the exhaust about 1 foot untill i hit the throtle again it is very bright and ushally pops as well i thought this was exhaust leaks but i had it in over the summer and the dealer replaced the doughnuts on two cylinders and it still happens . and it is louder then my friends 06 apex gt as well. any sugestions?
Shootinstick
sounds normal to me. My 07 Attak does it as well after a long wide open run.
Kind of cool.
Kind of cool.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
then why would it be so much louder then the other 3 in my group I think the dealer might have missed something
RTX Meirda
i heard the faster sleds throw flames?
how is yours in a race?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
It pulls the hardest out of the hole but is a little slower then two of the other 3 which brings me to my next question what is the best bang for the buck on top end?
Len Todd
It sounds to me like you have an exhaust leak. They probably should have replaced all 4 gaskets. Also, the gasket's clamps often have to have some metal removed between the clamp's two halves to get them to clamp tightly, especially around the reused donuts. Or, ... There could be a crack in the pipe/system. Also, one of the Flex-pipes could have gone bad. Sometimes they crack and then just let loose later. The cracks are hard to find, unless you are really looking.
I can't imagine a dealer just replacing two donuts. ??? I would be back in there looking for that leak.
This assumes that you have not done anything to lean out or change the fuel system.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
not yet but I do have a chip that is supose to go between the mass air flow sensor and the computer do you know any thing about that will it help or hurt the performance of the machine and will it harm the machine?
Len Todd
What exactly are you talking about here. Is it a PC III or something?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
It is a fast tuning motor management chip it says it works by modifying the signial to the ecu or computer for a more efficient air fuel mixture. it is adjustable for 0-30 hp gain as they claim just by turning the knob
yamahahaapex
lol i think a guy posted info on that so called chip. Most aftermarket hp gain are roughly $500.00 or more per hp. Check the apex/attak forum. Think NOS-PRO had a post
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The adjustable chip is a variable resistor, that's all. Save your money, in my opinion, you'll never see 30 HP from it.
http://www.ty4stroke.com/viewtopic.php? ... t=resistor
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
thank you for the info you guys are great
Love this site
Love this site
irondog rtx
ok heres whats up your header pipes are getting worn around the bell my friend s sled did the same and started back firing take the seat of and run the sled and you will feel it leak there at the clamps bet this is whats wrong also does the sled have around 2500 miles plus
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
yes it has 3300 miles on it but it has been doing it since i got it last year with 266 miles on it.dealer told me to run it and they would fix it over the summer well they didnt get it right i guess
Len Todd
Sometimes you have to modify the clamps on the Donuts. Remove about 1/8" of metal where the two clamps come together. This allows the clamp to go tighter.
