Hi Guys left my machine out in -35 started it and now i have no lights guage is fine but no headlights or taillights checked fusses all is well helppp??? its in the warm garage if i go out there and lights work thats great but what would cause this??
Tom
Tom
I am going out on a limb here, and someone more knowledgeable please chime in, but I have had similar issues in real cold weather. It would take longer to come on than normal. I am guessing there is a relay for the headlights that activates after the machine starts, and your relay is frozen. It should work fine once it warms up. I guess this is a somewhat common occurrence with the fuel pump relay. Some people just carry a spare in their coat pocket where it is a little warmer, and swap out when needed.
On a side note, I had an 06 Nytro with that issue. Also nothing in the spedo was working. If you lost your spedo/gage cluster, I would say you did blow a fuse. That was the issue with mine.
nb-attak
remove left side panel (clutch side). there is four relays that are located above your left foot well. it is the first one at your disposal that is the headlight relay.
tttario
Pretty sure my lights don't come on until the red light goes off. Thought it was a safety thing so you don't drive it until warm. The lights turn on the second the red warmup light shuts off???????
nb-attak
nope, lights turn on the instant the sled runs.
copo427ss
relay
tttario said:Pretty sure my lights don't come on until the red light goes off. Thought it was a safety thing so you don't drive it until warm. The lights turn on the second the red warmup light shuts off???????
My lights come on right when I start the sled up. In severe cold it has taken a couple of extra seconds for them to turn on, but nothing extreme.
tttario
jwifferdill said:tttario said:Pretty sure my lights don't come on until the red light goes off. Thought it was a safety thing so you don't drive it until warm. The lights turn on the second the red warmup light shuts off???????
My bad. Must have been another $10 parts screwing my sled up.
Changed all 4 Wednesday so hopefully this #*$&@ gets straightened out.
