k-9 03
How are you guys setting up your suspension on the Attak Gts before your first ride. Any tips or pointers you have would be great. Thanks
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
k-9 03 said:How are you guys setting up your suspension on the Attak Gts before your first ride. Any tips or pointers you have would be great. Thanks
Make sure your rear suspension sit in is correct (Same procedure as outlined in the "Sticky" post). I like mine with the ski springs (Front of sled off ground) loostened up to where there is about a half an inch gap between the top of the springs and the adjustment collars. I have the limiter strap set in the 3rd pair of holes from the bottom (This was shortened 1 pair from where I received it) Transfer is set slightly better than half way. I am running 108 studs down the middle and a 13mm sway bar. Front shocks are set very soft on compression and about half way on rebound. Rear shock is set about 3/4 firm on the rebound.
I am still experimenting but like this setup much better than how I started out.
Hope this helps!
k-9 03
Thanks Ill check it out. What do you weigh? Im about 200 in gear.Soldier'spapa said:k-9 03 said:How are you guys setting up your suspension on the Attak Gts before your first ride. Any tips or pointers you have would be great. Thanks
Hope this helps!
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
Hope this helps![/quote]
Thanks Ill check it out. What do you weigh? Im about 200 in gear.[/quote]
I am about 220 w/gear.
As you can see in my signature, I am no longer running the stock skis. I opted for a wider ski for better floatation and less darting.
- 148K
