I know there are comp and rebound adjusters but where are they? At the bottom of the shock where the reservoir is a brass screw. is this comp adjuster or rebound? where is the second adjuster? I dont see another one. If someone can help me out that would be great. Im getting some kick up from the rear and would like to dial it out if possible.
Yeah the Front ski shocks on the FX are the only ones that have rebound adjustments. Those are on the bottom of the front ski shocks. The center shock has no adjustments, only spring preload. The rear shock only has the compression adjustment that you mentioned.
