looking to get a phazer, it just is up to which year to get. I understand that there were some changes in '09. Is it worth the extra money (approx $1500) to go with the '09?
Yamahajrp
if its an 07 make sure the updates and recalls are done, not sure what all they changed in 09
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
the 09 would be worth it if all the updates where not done with the 07 and the rear hole on the Phazer tunnel is closed off on 2009(the 07 from the factory was open)
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
What is millage on each and what models are they?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
the only "Issues" 09' had left was the possibility starter bolts coming loose (the long ones that hold it together) and the grounding block, everything else way fixed. 09's also have the 3rd revision of the front skid arm/shock cam setup which is pretty beefy and I really haven't seen anyone bust or crack one.
- Nov 1, 2009
- 2009 Phazer RTX
I have almost 7000km's on my 09. Starter bolt are good, I think they where fixed before and the grounding block has not given me any problems.
My relay's have frozen once before that that was it.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
The 09 has slightly different plastic around the gas tank. I think it looks a little smoother than the older models.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
I personaly would spend the extra cash for s 2 year newer sled.
jlparker77
Didn't the 07 have a bigger fuel tank?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
2007 Phazer "RTX"
jlparker77 said:Didn't the 07 have a bigger fuel tank?
Yeah. I think the thickness of the tank increased to keep fumes in or something.
jlparker77
That's what i was thinking. but didn't turn into like almost a gallon difference? or maybe not quite that much, but it was a considerable difference.
- Nov 1, 2009
- 2009 Phazer RTX
If I remember right it was something about environmental standards.
Even with less fuel capacity I would go with the 09. What models where you looking at? If it is an 09 RTX, some of the price difference is in the shocks.
Here is a list of changes.
http://www.ty4stroke.com/viewtopic.php?t=107506
