theCATman
- Feb 19, 2007
- WI
- Yamaha
Rode 55 miles yesterday. Daughter on this Vector. Got home, unloaded sleds, and at slow speeds there is a light tappity/clunky noise that appears to be coming from the chaincase. I asked her if she noticed anything and she said she heard a clunk that sounded like under her feet, but nothing after. Anything faster than say 10 mph, no noise is heard.
I have the chaincase torn apart, oil was clean, no metal, no damage to any gears or chain. I inspected both upper and lower bearings, both appear fine.
As I rotate the assembly with a socket and ratchet off the lower sprocket, everything is buttery smooth. Now, with the secondary on I can get an occasional noise from it, but can't obviously spin it fast enough. With secondary off, no noises and still buttery smooth.
Pucks on secondary are fine. Belt is good. Anybody have any other suggestions? I'm at a loss.
Any chance it's a noise with the secondary that's traveling thru the jack shaft and making it appear it's from the chaincase??
Both jackshaft & driveshaft bearings have been repacked within last 200 miles.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Chain tension is lightly finger tight and backed off 1/4 turn. That was 1st thing I checked.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Well, if I were drunk at least I'd have an excuse. I just got really good at taking a chaincase apart and reassembling.
Got everything back together except the parking brake. Dead silence minus the clutch rattle. I'm like WTF.
Put the parking brake back on, tappity clunky grindy noise is back. It was the motherphucking parking brake the whole time. At least I can laugh at myself.
Insert best Homer Simpson.... DOH!!!!
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Glad you found the problem
