07 vector wiring diagram help
rough rider
minnesota
Hi does anyone have a wiring diagram for a vector, I need to know what color the power wire is that goes to high/low beam button. the old Yamahas used to have a blue wire suppling juice to switch and a green and yellow wire going to headlight for low and high beam, Just not sure what color it is on these newer sleds. Thanks for any info :4STroke:
According to my '06 service manual (probably the same for '07), there is a blue/white wire running from the headlight fuse to the hi/lo switch and the headlight relay power terminal. A light green wire runs from the hi/lo switch to the headlight relay coil. The relay switches the power coming from the fuse (blue/white wire) to either a green or yellow wire for the high or low beam lamp filaments. Not sure which wire (green or yellow) is high or low beam by looking at the wiring diagram.
Martin
'06 Vector GT
wiring
mbw919 thanks for the info, that is what I needed to know, I have to invest in a service manual or cd, Thanks, Roughrider
