apeddigrew
- Mar 5, 2011
- St. John's, Newfoundland, Canada
While on a 2 nite back country run my sled would not start Sun Morning. it started Sat mornin no problem, had a ~~190 km day w/ no issues at all. sled ran great. It started and ran fine friday as well. Sun morning, not as cold as Sat morning, the fuel pump won't cycle when the key is turned on. (new battery installed on thursday, new ignition relay about 2 weeks ago.)
seems like a frozen fuel pump?? i tried some gas line antifreeze, no luck, tried to locate the fuel pump to wrap with warm rag or something but can't find the pump!
after a 14km tow, and 2.5 hr drive home the pump cycles and sled starts before removing from truck! however the headlight doesn't come on right away, then light comes on after a few minutes??
Anyone out there aware of a similar type of problem with thoughts or comments?
Thanks much guys
Andre
Thanks much guys
Andre
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
More than likely, it's the fuel pump relay. Fuel pump itself is in the tank so not likely it froze. Replace it with the new solid state fuel pump relay number 8GN-81950-00. Also replace the load control relay, which controls power to the lights once the motor is started. Could be that once the sled warmed up a bit the relay finally worked and turned on the lights.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Mooseman said:More than likely, it's the fuel pump relay. Fuel pump itself is in the tank so not likely it froze. Replace it with the new solid state fuel pump relay number 8GN-81950-00. Also replace the load control relay, which controls power to the lights once the motor is started. Could be that once the sled warmed up a bit the relay finally worked and turned on the lights.
x2!
apeddigrew
- Mar 5, 2011
07 VL fuel pump
Thanks very much Moose man. The relay cluster, is that under or behind the battery somewhere? And how do u know which is which?
Thanks again.
Ap
Thanks again.
Ap
fuel pump is an in tank unit.
sounds like you had a frozen fuel pump relay (x3). common on the fuelie yamahas. relays look like they are located on the right side of the sled from parts diagram.
Wacko
- Mar 24, 2013
Re: 07 VL fuel pump
They are between the battery and engine. On the mp, it's the top 2 middle relays
The second from the left is load, and third is the fuel relay.
apeddigrew said:Thanks very much Moose man. The relay cluster, is that under or behind the battery somewhere? And how do u know which is which?
Thanks again.
Ap
Eastern wind
- Mar 4, 2014
- Fredericton NB
- 2008 Venture MP
MP issues...
I had much the same thing happen to me this weekend... we went maybe 20 K... stopped shut the sled off... tried to start it... couldn't hear the Fuel pump kick in... also the head lights wouldn't come on... but on the dash the High beam indicator flashed on for a sec and then shut off... left the sled for a day.. came back expecting to have to tow it... and it fired right up...ran it home... put it on the truck to take it to the dealer...salesman told me of the relay issue... also of a ground issue that was a recall/service bulletin...talked to the tech at the dealer... all he could think of was the relay... he ordered the solid state part in.... anyone else seen the high beam lite flash during this ordeal..?... and I say ordeal when you are miles from home
Thanx
Thanx
BombaPolaYama
In a pinch you can find a way to warm up the relays and they should work to get you back home.
asmerch204
- Feb 19, 2014
- Winterpeg, Manitoba
- 2008 VL slowly turning into a MP
It happened to me last weekend as well (-34c). Tried a hand warmer on the relays for about 10 min to no avail. Pulled out the thermos, poured hot tea on the relays and the pump fired right away. Even the yammy needs some green tea every now and again!
Eastern wind
- Mar 4, 2014
- Fredericton NB
- 2008 Venture MP
the tech at the Yammy dealer here in Fredericton ordered me the 'Red' solid state relay... but I think there was a wiring issue that was sent out as a bulletin as well...
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It almost sounds like it's the relay but the high beam light flashing is strange. How long was it stopped when you tried to re-start it? It's usually when it is stone cold in very cold weather.
The dealer should check for melting of the ground block which is taped up in the wiring harness located between the oil tan and radiator. Also should check the ground wire connector running from the battery. I had one that was frayed and partially disconnected which also cause some weird boogaboos.
http://www.ty4stroke.com/viewtopic.php? ... ine+random
Eastern wind
- Mar 4, 2014
- Fredericton NB
- 2008 Venture MP
Thanx Moose Man
yeah... he was going to top t bottom the machine.. he said some of the ground wires looked a little less than perfect... he was going to add on the piece of harness that was noted in the service bulletin...it was shut off for about 10 minutes in maybe -15... I'm thinking ground issue as well..I have not heard anything about the hi-beam indicator flashing but one would think it would be a sign from the Yamaha gods I hate to talk poop about techs... but this guy didn't seem to have much of a clue about what he was doing... situations like those worry me..if and when I get it sorted I will post what the issue was...I am one perplexed Newfoundlander...
BombaPolaYama
.........in New Brunswick!Eastern wind said:Thanx Moose Man
Eastern wind
- Mar 4, 2014
- Fredericton NB
- 2008 Venture MP
yep... In Fredericton NB no less... retired military...seemed like a nice place to be...
Rippr76
Any resolution to this issue, my 09 is having very similar issues. Will run fine one minute then the high beam indicator will come on, sled dies and won't restart, or even crank.While on a 2 nite back country run my sled would not start Sun Morning. it started Sat mornin no problem, had a ~~190 km day w/ no issues at all. sled ran great. It started and ran fine friday as well. Sun morning, not as cold as Sat morning, the fuel pump won't cycle when the key is turned on. (new battery installed on thursday, new ignition relay about 2 weeks ago.)
Thanks much guys
Andre
