dukemerc
- Dec 7, 2012
anybody have problems with the exhaust clamps under the tank,mine i guess from vibration rotated and the clamp got against the tunnel and man did that make a noise i thought a main bearing was gone,i tried so shave a little off the spacer that i welded to the clamp but the noise is back so im tearing it apart again,anybody have an idea mabe a little exhaust patch on the clamp? tack weld? thanks for any info... duke
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Usually the clamps rotate because the donuts (gaskets) are shot.
boritzer1234
The clanging is due to the exhaust doughnuts being shot and those clamps are vibrating because they are bad. I would recommend placing copper doughnuts in it and call it good. It's a bit of work but sounds like you've had it apart already.
dukemerc
- Dec 7, 2012
thanks for the help ill give it a try....
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Yeah, definately get copper donuts and grind off a couple millimeters of the spacer.
