Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Just wanted to update all 08 FX Nytro owners that their is now a deflector plate available from Yamaha to help reduce the amount of moisture that makes it into the left footwell area. The 2009 FX Nytro models have a deflector plate installed below the drive clutches to reduce the amount of moisture in the footwell. The 2009 deflector plate (8GL-2197B-00-00) can easily be installed on any 2008 FX Nytro model using two existing 8mm bolts. The deflector plate retails for $27.04 and we will be selling them for $22.70 for TY members. Feel free to enter the part number on our online fiche program below or give me a call if you need one. Thanks
http://www.portyamaha.com/fiche_select.asp
CROW
When can we expect to see the compete 2009 fiche??
TurboMatt
I put one on my '08 already. I'm really curious to see if it is actually going to work.
errol
- May 24, 2003
- Quebec, QC
- 2018 SW B-TX LE 50th
2jzpgt said:I put one on my '08 already. I'm really curious to see if it is actually going to work.
Same here!
ShootToThrill
It really works!
Bodacious
You have had a chace to test it already?cwcsrx700 said:It really works!
ShootToThrill
Yep check out the 121 Nytro forum.
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
CROW said:When can we expect to see the compete 2009 fiche??
I don't have an exact timeframe as to when the 09 fiche will be up on our site but I will try to make a post in our vendor section when it becomes availble. I you need pricing or have questions on any of the 09 parts feel free to give me a call as I have access to the 09 fiche at the shop. Thanks
- Apr 14, 2003
- Hessel, Michigan
Kevin, got mine!
Thank You!
Port Yamaha ROCKS!
Thank You!
Port Yamaha ROCKS!
MattMac1
Dropped my sled off today for a few goodies, found out this deflection plate is covered by warranty, dealer should have a memo on it.
Butta
MattMac1 said:Dropped my sled off today for a few goodies, found out this deflection plate is covered by warranty, dealer should have a memo on it.
Covered by warranty?? More info on this, please....
MattMac1
There is not much info. I order one and when I drop of the sled was told warranty would cover it. The dealer had a service notice stating that if a customer comes in complaining about their left foot getting wet to install the deflection plate under warranty. Plate changes the air flow under the secondary so hopefully foot stays dry.
KINS
Butta said:MattMac1 said:Dropped my sled off today for a few goodies, found out this deflection plate is covered by warranty, dealer should have a memo on it.
I ordered one as well and was told it would be covered by warranty.
Goddo
- Nov 4, 2006
- 19 miles from Lewis Hills...Oh Ya.
KINS said:Butta said:MattMac1 said:Dropped my sled off today for a few goodies, found out this deflection plate is covered by warranty, dealer should have a memo on it.
Interesting...Last time I was up, KMAC wasn't sure if it would be covered...Cool, & the gang...
Jiggy
I picked one up, but was wondering how to install it. Anyone able to take a picture of one already installed?
- 6K
