08 phaser code 81 won't crank over
V-maximum
Robinsons,Newfoundland
Shows code 81 I've disconnected the handwarmers and checked all the fuses. All the connections look good. It was cranking over at first but now it's not doing nothing. I've tryed different battery's still the same. All fuses are good. When I cross out the solenoid it turns over but won't start. Looking for the grounding points. Fuel pump not kicking in at all. If I hold the key on code 43 flashes as well. The self was working perfect shut it off with the kill switch n it would start n cut out at first now it does nothing :o|
