Looking to send the Öhlins® Mono Shock® EC 136; 46 mm Öhlins® w/ electronic compression to Pioneer for a new spring (6.5 or 7.1) and shock rebuild. Any tips on removing and replacing the shock?
I loosen the track, put the sled on its side and pull the bolts (and disconnect the harness). It'll slide right out.
To install I remove the rear bolt from the transfer rod to make it alittle easier to line up the shock bolts. Then set the sled back on the ground and put the transfer rod bolt back in. Adjust and align the track to spec....
