I looked up oem ltx part stock was a 136.
What is the best option to go to 144 extension wise? Use ltx oem parts or aftermarket parts?
if i remeber correctly there was track tensioning issues when you went over 136" with the mono shock until the single shot came out. never owned one but did read up on the issues at the time.
Ok thank you. I did some searching and most loved the 144 setup. Just trying to cover everything before I buy stuff
Still searching the 144 options. Not sure what to do seems like you need
Tunnel extension
Rail extensions
Rear heat exchanger
Anti drivers..have to run track very loose
Tunnel extension
Rail extensions
Rear heat exchanger
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Can't comment on the anti drivers. On my 06 I went to a 136. I needed a tunnel extension, rail extensions. I skipped heat exchanger but generally ride in good snow in upper MI. That said my scratchers have not been deployed the last two seasons but this is a 136.
The rear exchanger should of been a tube back there. Did the tunnel extension go around that?
