Goddo
- Nov 4, 2006
- 19 miles from Lewis Hills...Oh Ya.
gade-thrasher said:Just some information for you guys....
I did quite a bit of investigation into the grips on my '06 Nytro. This same problem reared it ugly head way back then. To make a long story short, the '06 grips were cold, the '07 update kit wasn't any better ... the solution was to use the '06 grips wired in the '07 fashion. i'm sure many of you have seen the 40 or 50 page thread on this topic.
This situation will be no different on your FX Nytros. And when you measure the voltage at different RPMs, or settings you will find no change. I measured the voltage output using a Fluke meter (kinda-like an oscilliscope). The voltage actually never changes with different settings. The voltage is always 12V. What does change is the signal. It is a PWM waveform ... that simply turns on/off at different rates for different settings.
Think of it this way ... turn a light switch on, then quickly turn it off. Then wait a while and repeat. This is like a low setting on the warmers. For a higher setting the on time of the light is longer, and the off time is shorter. This is what creates more heat.
Now, if you want to add a resistor to get more current, and thus increase the wattage ... your thinking along the right path. Putting a resistor in parallel with the grips will drop the total resistance, and allow more current to flow, thus increasing the wattage. HOWEVER ... you will not get any more heat. This is because you will have increased the total current draw, not the current draw through the grips themselves.
So here are your options ... Option 1 - change out to the '06 grips offered by Yamaha if you can find them. Your newer sleds will already be wired correctly for them to work. Option 2 - get some aftermarket grips that have a higher wattage.
Trust me on this analysis .... my day-job is Electrical Engineer.
Now that's an informative post...Thanks GT. The worst part of that post is it doesn't provide much in the way of options. Either way it involves changing grips.
