fxnytro1050
I'm planning on upgrading my nitrous track from a 1in to a 1.5 or 1.75. Ibwas told that I would have to remove the two bars that run up from my rad to the snowflap. I was also told that all they are there for is protection from studs and I don't use a studded track and never will. I was wondering if the rad actually had the rad fluid running through the fins. I no it sounds stupid but I herd that it doesn't?
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
fxnytro1050 said:I'm planning on upgrading my nitrous track from a 1in to a 1.5 or 1.75. Ibwas told that I would have to remove the two bars that run up from my rad to the snowflap. I was also told that all they are there for is protection from studs and I don't use a studded track and never will. I was wondering if the rad actually had the rad fluid running through the fins. I no it sounds stupid but I herd that it doesn't?
no the tunnel protectors are there just to protect your exhaust from getting rubbed from the track, there is no fluid running thru them.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Cut them off, it will help big time with ice build up too.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Be careful when cutting off the cooler protectors. If you cut too deep green fluid will be coming out..
Take your time with a dremel and a good cutting wheel and you will be fine.
Don't forget to use safety glasses in there...
Good luck
Good luck
