09 XTX help
I wish I would have known about that Star Suspension before putting on Hygears and X-Click blocks
Chris Schmidt (Schmidt Bros) can help you with your handeling problem.
Center shock up grade
scott32 said:
shaddow44 said:
I just checked out that link...they have something I'm very interested in..the 128" kit for the RTX, however my french is nonexistant...it looks very interesting as the apporach angle is not so aggressive.
This 128" kit is essentually the same idea as the skinz concept front end. It lengthens the wheel base (changing the fulcrum) and stabilizes the weight sensative mannerisms of the nytro. Hopefully Yamaha does this for 2013.
Changing the fulcrum doesn't push the weight back off of the skis though. The skinz concept helps to allow the skis to pull the front end weight around the corner. Without pushing the skis forward, there is still all of that weight right on top of them creating "push" in the corners.
Installing one apex mountian torsion spring(along with the hygear spacers), and a fox zero pro rear shock from carver made the suspension feel like it acually moves when your riding over bumps.
What do you mean by "installing one apex mtn spring"?
are the same issues with the base Nytro (2010)?
havent ridden it yet so dont know what to expect. I know we have a rail line on our local system that gets brutal for bumps and am hoping this will just cruise along over the bumps
