eskimonytroxtx
I have a 09 xtx with 4500 miles. Last winter it started to show a couple of codes. a code 12 and a code 43. Sometimes when i start it there is no head lights. while its warming up they come back on. And when its really cold out, it acts like it has a weak battery too sometimes. Any one here that can help me with this problem? Thank you in advance
Zakre
eskimonytroxtx said:I have a 09 xtx with 4500 miles. Last winter it started to show a couple of codes. a code 12 and a code 43. Sometimes when i start it there is no head lights. while its warming up they come back on. And when its really cold out, it acts like it has a weak battery too sometimes. Any one here that can help me with this problem? Thank you in advance
First thing i would do is pull the starter relay( green thing near battery)and then pull the relays(3 i think they are black) under the headlight (pull of the hood and you will see them) Bring them into your house for a few days let them dry out. Usually snow just gets into them and freezes up thus they sometimes work and other times not. Let us know how it goes.
radianguy
- Jan 1, 2007
error codes here
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
Sounds to me like you have a weak battery, remove it and take it into a auto parts store for a free test.
usaf167aw
now that you say that thing about the head lights being delayed coming on mine did that a few times also? is that caused by one of the relays freezing up? then getting warm and thawing out?
eskimonytroxtx
I charged the battery all the way. still the same, i think its the green fuse thingy. and those black boxes in front of the engine. I hair dried them and it seemed to work
grumpysanta
yes yamaha has had this problem for years on a lot of sled , i had the same think on my srx but not sxr or rxi so far..
blew by you
I'm having a code 12 on my 08Nytro also,i pulled the green fuse and put a jumper wire across the 2 prongs...still code 12 id hate to buy a starter relay assembly for nothing
any suggestions would be greatly appreciated
eskimonytroxtx
I think the error codes go away if u reset them. there is a certain way to do that but i still need to figure it out, lol.
blew by you
anybody
Zakre
Code 12: Crankshaft Position Sensor
Code 43: Fuel System Voltage
Have you load tested you battery yet? Or checked out the relays?? You need to tell us what you have done, Checked the wire harnesses?
