drunkenrich
Took 6tons of press for them to let go. Press new ones in around 5ton
drunkenrich
My skis have alot of left to right play in them, bushings? What do you guys think?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Ski spindle bushings. I couldn't find the link in the Nytro section so here's from the Phazers:
http://www.ty4stroke.com/threads/phazer-riders-check-spindle-ovaling-where-ski-mounts.84758/
drunkenrich
Thanks moose, was this kit a hard install? How would one know if their spindle was too far gone to save?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Not really hard to install. If the spindle is really bad, it might be saved using a product to fill in the spaces between the new stainless bushing and the spindle. UpBushman will be able to help you out on this.
NS FX NYTRO
How much play is too much play? I'm just reading through some posts in this thread and see some people have lower ball joint play after very few miles (and in op's case right from install). Mine have a little play up and down, but no where near bad. The play has been the same since 3000 km ago (beginning of last season) ski bushings are decent and I installed oilites in a arms. I lube all ball joints and tie rod ends often throughout the winter, maybe this helps?
radianguy
- Jan 1, 2007
I've seen play in new sleds sitting on dealers floors! Crappy design
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
As they get more play, they'll get pounded out faster. The tech exchange bulletin from Yamaha says the wear limit is 1.2mm (0.05 in.). Upper ball joint limit is 0.6mm (0.02 in.)
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
The book says the balljoint replaces yamaha part # 8gk-23579-00-00 but yamaha upgraded the balljoint part # to 8gk-23579-01-00 for 08 and the 09 nytros use the 01-00 part#. Whats the difference?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Probably just better material to make it last longer. Physically the same.
NS FX NYTRO
The updated 08 ball joints and the 09 look completely different on the Yamaha parts fiche.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
My son's 09 Phazer ball joints looked the same as the 07 before they died.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Ulmers has done awesome oilite bushings for a-arms and ski spindle bushings. And very reasonable price
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The newer style ball joint is a three piece design, I believe started for 2010 model year. Spherical bearing with two collars that go top and bottom to get it to the same overall height as the original. If you update to the newer style, you'll need to order the collars as well. Items #31 x 2 and #25 or 29 x 1 , per side.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Must be something you did because I got the email notification of your post and got it all:
And your dancing banana don't dance no more![]()
WTH the banana doesn't rock, damn just noticed after reading that post & all these months later LOL!
Still does on my profile page though, oh well.
\m/
