Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
Was wondering, does the 04' RX1 have the same tunnel and heat exchanger protectors as my 03'? It seems a bit tight, and I noticed way more track noise and a bit more vibration after changing my stock 121" track to a Rip Saw 121" 1.25" track. Just wondering if anyone has noticed the same, and if the protectors are all the same.
Thanks,
Steve Burdick
Thanks,
Steve Burdick
LazyBastard
Protectors are all the same. If you have any more noise, you probably bent a heat exchanger slightly, allowing it to resonate. I've got a nasty vibration out of my front left heat shield.
Ripsaw's are noisier than finger or 6-pitch tracks, they will make a resonating hum.
Vmax4
- Apr 18, 2003
- Orondo, WA
03' tunnel and heat exchangers same as 04'
Is there a diameter size change on the 04', or is it exactly the same???
