Got my temp gauge installed.
TBay Sledhead
Thunder Bay, Ontario.Ca
Canada
06 Attak
01 SXR Long Track
Well I finally got my temp gauge installed after 3 weeks waiting. Inadvertently ordered a temp sending unit adapter from china, couldn't find the right size in town. Took the slow boat from China, nice piece of work though.
Looks good. I'm thinking of doing the same but don't know where to mount the gauge. Can u post some pics of how u mounted it. Also I like that gauge where did u get it and how much?
This is the gauge that I used. Comes with mounting pod. $71. I don't know if this gauge will hold up to the pounding though,also the gauge has a button on the front that needs to be sealed. I think that the digital gauge that they sell would have been a better option. To mount I just drilled a hole thru the back of the cup and gauge cluster pod and put a double nut on the back. There was a gap between the cup and pod so I made 2 1/4" thick donuts from rubber and put them over the screw before assembly that tightened things up.
http://prosportgauges.com/Blue-white-pr ... ture-.aspx
This gauge is the digital version, maybe a better option but need to buy the mounting cup. http://prosportgauges.com/Digital-water ... uge-1.aspx
Cup http://prosportgauges.com/52mm_Premium_ ... g_Cup.aspx
If you check this post it gave me the idea. http://www.ty4stroke.com/viewtopic.php? ... t=prosport
THEY SELL THOSE ADAPTERS AT ROYAL DISTRIBUTING, BOUGHT ONE FOR MY ATV. THEY HAVE 3 OR 4 DIFFERENT SIZES
