ericms86
I am going to be installing a 1.5" crossover track on my XTX very shortly. I was wondering if it would be worth dropping the top gear a tooth while I have the chain case apart. I am not too concerned with top end speed as I am going to try to ride more deep snow this year. Would this be a better option than stock gearing?
Also just curious if I need to remove all of the tunnels protectors when installing this track.
Thanks for any input!
Turk
Tech Advisor
Definately drop 1 tooth if your in a lot of deep snow as this makes everything way more efficient under load.
You need to remove the front protecters for sure.
I would also remove the tunnel protecters as it really cuts down on the ice & snow build up.
Sask Attak
Where is the best place to get this top gear?
Turk
Tech Advisor
Post a wanted add for a 20 tooth top gear or ulmer racing can hook ya up.
ericms86
Thanks for the info Turk!
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I agree with Turk, the front needs to go and the tunnel protectors are up to your own preference.
