yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Good luck with that. He would know!
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
I would drop at least one tooth on top as well. I dropped 2 going to 136x.175
drewseph
I am going to try one thing at a time, dropping a tooth will be step 2.
Coincidentally revster, i just went through your build thread last night -- good work
revster
- Aug 18, 2004
- La Salle MB
drewseph said:I am going to try one thing at a time, dropping a tooth will be step 2.
Coincidentally revster, i just went through your build thread last night -- good work![]()
Thanks man.
I will soon be digging into it again. The next evolution is coming this year
drewseph
So whats the deal if i take a trip to revelstoke, or do alot of deep snow riding?.. recommended that i do go down a gear ?
revster
- Aug 18, 2004
- La Salle MB
drewseph said:So whats the deal if i take a trip to revelstoke, or do alot of deep snow riding?.. recommended that i do go down a gear ?
Yeah I would. If you are headed to the mountains or do a lot of off trail riding drop 2 teeth. When I do hit the trails I am still able to pull 94 mph indicated on speedo. (so likely 90). I am more then happy with that.
That gearing set-up has worked very well for me in the mountains. With the Schmidt Bros Stage II all I do is take the bolts out of the weights and run them empty.
drewseph
I think i would just drop one because im still only running 121''
drewseph
Finqlly got around to doing some clutching today. I put in a Yamaha white spring in the secondary and it seems to be running pretty good atm. Feels good to have that 4 stroke power back that can actually make this 1.75 paddle track hook up.
gc_srt
As you are a 121, you will need extroverts. While you are talking with Ulmer, I would drop a gear, clutch kit, and buy a set of K&N's.
I dropped to a 19T on mine. Works great, and putting a full intake and exhaust really helps with pickup.
drewseph
Thats the plan in the future I just don't have the cash right now
revster
- Aug 18, 2004
- La Salle MB
drewseph said:Thats the plan in the future I just don't have the cash right now
Have you changed your gearing yet?? I hope so otherwise you are stopping $35 short of making effective use of big lugs.
drewseph
Not yet. You really think I should?
revster
- Aug 18, 2004
- La Salle MB
drewseph said:Not yet. You really think I should?
It's what I can a no brainer. Match your gearing to your track.
- 14K
- 23K
