AllagashX
what is 100LL? where do you normaly find it \ avrage cost
Sorry for noobie question :exc:
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
Its avgas you can get it at airports. I never bought any yet the fall but last winter it was a around $10 a gallon here and $20 for race gas.
AllagashX
Holy #%@#?? quite expensive, Will be fun to turn her up once in a while tho. I think i can get avfuel around here
Turk
Tech Advisor
I am paying $1.20 a litr for 100LL in Manitoba. Works out to $4.80 per us gallon. Works good up to about 12-14 pounds boost
AllagashX
I like the sound of that! i will look for 100LL right now in my area. ty alot
yamiboost
- Feb 17, 2008
- Labrador,
Man i wish our gas was that cheap were paying more than that for regular 87octane gas here.Turk said:I am paying $1.20 a litr for 100LL in Manitoba. Works out to $4.80 per us gallon. Works good up to about 12-14 pounds boost
AllagashX
87 oct is 2.14 UsD where I am
rx1mountain
87 octane is $1.55 a gallon here in Iowa
fullthrottle800
I think lots of guys have ran it up to 20 pounds of boost and at 18 all day.Turk said:I am paying $1.20 a litr for 100LL in Manitoba. Works out to $4.80 per us gallon. Works good up to about 12-14 pounds boost
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Ontario reg 87 approx $.89 liter
100LL avgas about $1.49 liter
resurectedvikin
- Nov 7, 2008
doesn't avgas burn wicked dry? why not mix some 94 premium pump fuel with some racefuel from cars? 50/50 mix
Capt.Caveman
100LL at an airport is not to be sold with out applying the purchase to a airplane tail # (the # on the side of a plane).
But the law does allow it to be sold in plastic can with the tail # on the side of the can...Find a # Usally starts with the letter N and the airport should sell it to you...Good luck
yamiboost
- Feb 17, 2008
- Labrador,
Capt.Caveman said:100LL at an airport is not to be sold with out applying the purchase to a airplane tail # (the # on the side of a plane).
But the law does allow it to be sold in plastic can with the tail # on the side of the can...Find a # Usally starts with the letter N and the airport should sell it to you...Good luck[/quote
i have never had any problem and lots of the guys around here run it and i have never herd talk of this . I have even drove up to the airport on my attak once when i was out of town and filled up the same as if i were at ultramar although it can be messy airport pumps are much more pressure best to use a drum.
Capt.Caveman
Like I said FAA requires it to be dispensed into an airplane because of the low lead....I didn't say your airport follows the laws or others for that matter just what the owner of the airport that I hanger my plane at told me and how to get fuel for my sled...I thought it might help someone else that has an airport that follows the rules...try pulling up in your car and see how far you will get
And are you located in the country of Labrador??? I would say the laws are different
yamiboost
- Feb 17, 2008
- Labrador,
I guess at some of the large airports they would not sell it and yes maybe the rules are different here... I was just thinking that most small places you would not have a problem and if you are in a larger place then most likely you can get race gas and why why would you want av when you can get race.
