trail master
- Mar 5, 2015
- 2015 sr viper
Hi all, bought a 2015 ltx dx and was wondering if this sled has the 2 pin connector by the oil tank? I searched the site and found a pick just not sure if it's on the 2015. If so is the 12 volt power and ground and is it a fused circuit? Thanks you, Mike
Viper?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Viper?
Unless he just added it his "avitar" area says 2015 sr viper
Thats what I thought but he posted this in the RS Section... its a SR Viper. Ill just move the thread to the correct place.
SounderMN
- Sep 26, 2011
- Minneapolis, MN
- 2015 Yamaha Viper LTX DX
yes, it is 12 volt power and it has a fuse in the line. BTW, if the fuse blows, you lose the tail lights and the dash display. So make sure whatever you connect isn't likely to have a short. If you're trying to add a helmet plug, search the forum for many pictures and advice.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
THis is the only reason I am considering a fuse relocate as I understand it you have to remove the hood if you blow the fuse to get at it. Not happening on the trail for this cowboy.
SounderMN
- Sep 26, 2011
- Minneapolis, MN
correct-amundo. Guess how I know...
Anyway, I did the fuse relocation, and it was easy. Took about an hour. There is a very recent thread about it, and you can do it without buying a kit or any special parts.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
This is totally unacceptable! Next mod is to run the accessory outlet direct to the battery. Fused of course. What were they thinking?!yes, it is 12 volt power and it has a fuse in the line. BTW, if the fuse blows, you lose the tail lights and the dash display..
SounderMN
- Sep 26, 2011
- Minneapolis, MN
It has a fuse in line, so nothing will be broken. If the dash goes out, you can still ride. It won't leave you stranded... you just can't tell how fast you are going. They have only a few fuses on these machines so they combined circuits... perhaps not in the best way. I assume the electrical system is an AC setup, not a Yamaha setup, so you can talk to your dealer about it!
