BLUE LIGHTNING
OKAY GUYS,
I hear about these 12/13 mm sway bars, i have trouble keeping the inside ski to the ground on my 2006 attak, am only 170lbs and want a better way to take the corners, lean as far as i can and still have trouble keepin it down or relatively close to the ground. any ideas and do u guys think this bigger sway bar will dramatically improve my cornerin ability? any ideas would help!!! tryin to gain weight but can't modify my appetite!! also wheres the best place to get them from? thanks
JP
JP
LazyBastard
Yes, the 12/13mm bars work wonders. Some people feel that the 13mm is too stiff, but that can depend on rider preference and the actual sled... typically, the models with the short spindles don't need as much swaybar as the models with long spindles (03-05RX). Most people get the bars from pioneer - check the vendors section.
BLUE LIGHTNING
thanks LB, any ideas on what one to get? its for a 2006 attak, not sure never ridden one with any aftermarket swaybar. like u say rider preference, jsut dont want to get one and have to get another ones cuz it not the right one,, any ideas?
JP
JP
LazyBastard
I run a 13 myself, but I have long spindles. You have a 136 with a lot of metal, so it will have a greater tendency to push and roll in corners than an unstudded 121. I would tend towards the 13, but again, rider preference.
- 6K
