ualav8
can someone give me the how-to in filling and bleeding the coolant on a 13 apex? Actual pages out of the service manual would be appreciated
PM sent. Procedure is from a 2008 but it should be the same.
ualav8
I can't find the bleeder. If it's there, I have to remove about 20 rivets to get at it
![](/styles/vip.gif)
Winderallday!
I think if you remove the seat and the rear trim surrounding the exhaust, there should be an access hole through the tunnel to get at the bleed screw in the rear heat exchanger. This is where I have always bled the air out of the coolant system.
