it wont fit at all on the arms,even tryed spreading the arms ,this thing cant be right ,if anyone can help or have seen this before
did i need to get the arms too?
i wonder if pio- sent me the wrong one???
gary~
lap top dieing , if you can call me it would be a great help
413 267 9369 its
gary~
413 267 9369 its
chadman
Weight off the front. There was a post on here a while back, looked very easy.
trailnazi
i installed one. it was easy. take the weight off the front. i had a hard time getting one side of the bar into the armbut i spread it slightly with a small screwdriver and she popped in nicely. oh ya. this really makes your machine rail. loosen your front shocks four turns and decrease your weight transfer.to 3/4.
SRX Rocket
pro116
viperyder said:it wont fit at all on the arms,even tryed spreading the arms ,this thing cant be right ,if anyone can help or have seen this before
gary~
what kind of sled do you have.
MyOutdoors
I had the same problem, 1 side fit the other wouldn't, to the point where I thought it was wrong also. I tried to spread open a little and still had to use a hammer to set arm all the way into rod...yes splines were aligned! the other end went in fine. Work it a little, they go in.
found the problem,i wasnt pressing hard enough,for some reason,one of the sides fitts ,ALOT tighter than the other ,weird
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I beleive if you have an RX-1 model, you need the arms. If you have an Apex/Attak, it will fit just fine. I have installed 1 on my RTX, and now will be going into my new Attak.
1CS
1CS
LazyBastard
Its just 03 that you need the links for. 04+, everything will work.
Black 1000
Just did this mod to my 03 and love it
NY_Nytro
I just put a 13mm in my Nytro and the arms were very difficult to put on. Even with spreading them open I still needed to hammer them on. Bruce @ Pioneer sort of warned me of this by telling me to install and remove both arms before installing the bar in the sled.
98Slim
Tight Fit
Same problem, I heated up the alum piece which expenaded it a bit and both sides fit fine.
SharkAttak
i installed the 13mm sway bar last week rode 400 mi. last week and it still seems to get alot of ski lift in the corners
- 6K
