Jeckylll
- Nov 17, 2007
- Saskatoon, Saskatachewan, Canada
Do any of the sponsers sell the 13 mm sway bar for a 2006 Apex GT? If not who do i get one from?
The body roll in the corners getting to me.
kotapug
richmotorsports
pioneer suspension
pioneer suspension
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Pioneer Performance is the only one I am aware of.. He is an sponsor here as well.
Jeckylll
- Nov 17, 2007
thanks
Tantrum
- Oct 26, 2007
- NJ/NH
- www.adrenalinecam.com
Spoke to Bruce today, they are on back order but he is expecting them in any day now. I want to try one.
64ssmax
can some one school me on sway bars for attack gt's? will a larger sway bar help keep the skis down in the corners?
brian
brian
tttario
64ssmax said:can some one school me on sway bars for attack gt's? will a larger sway bar help keep the skis down in the corners?
brian
Larger the sway bar the flater the front end stays through the corner. Stock is 11mm. Most guys recommend as a must for these sleds. I am getting one shortly too!
Trev
Apex_GT
Wouldn't a 13mm sway bar increase ski pressure? I would think it would dart more like this..
snowdreamin
It does`nt change ski pressure It just ties them together better
ROCKRTX
Put the 13mm sway bar and set your shock lower down with limiter strap tighten 1 hole.
With good carbite or ski, your sled will rail on corner.
JERSEYJOE
THIS IS THE TRUTH
THIS IS THE GOSPEL TRUTH.
Apex_GT
ROCKRTX said:Put the 13mm sway bar and set your shock lower down with limiter strap tighten 1 hole.
With good carbite or ski, your sled will rail on corner.![]()
Yeah but you have 192 studs..So maybe for that set-up..DOn't think it would be good for someone who is 170 ibs and has 96 studs
ROCKRTX
Apex_GT said:ROCKRTX said:Put the 13mm sway bar and set your shock lower down with limiter strap tighten 1 hole.
Why not????........
Apex_GT
well I'm thinking your heavier than 170 ibs...So more weight in the back plus all those extra studs would suggest you would need to lower and plant the front end more..It sounds like it would be too much for my weight and set-up..ie heavy steering and over steer
ROCKRTX
I only weight 155,tighten the limiter strap 1 hole lower the front end,plus i put my fox float at 55psi(lower spring pressure on the gt).the 13m sway bar reduce ski lift,the other 2 adjustment put more pressure on the front of the ski for better bite in the corner.for over steer adjust your weight transfer.
- 9K
