13mm sway bar
ROCKRTX said:
I only weight 155,tighten the limiter strap 1 hole lower the front end,plus i put my fox float at 55psi(lower spring pressure on the gt).the 13m sway bar reduce ski lift,the other 2 adjustment put more pressure on the front of the ski for better bite in the corner.for over steer adjust your weight transfer.
Interesting..I am playing around with the suspension at the moment..I just loosened the front springs. Pretty much as loose as it could go before the spring would come up....My sled was a lil twitchy and I thought that might help get it perfect..The limiter strap is at its looseist setting..I thought that was the wieght transfer thing..How do you adjust that?
Adjust by the weight transfer rod,the bottom aluminum tube between the front and rear pivot arm.loose the tube for more weight transfer,tighten the tube for less weight transfer.I use the limiter strap to adjust ski pressure,but it also affect how the suspension react in the bump.
Take some time to adjust your suspension,there is a lot of gain in ride quality and how the sled react for your riding style.
