Sask Attak
I want to extend my Attak to a 144 x 1.5" Will I need to change gearing or anything of the sort? What track do you recommend for 75% off and 25% on trail? Thanks fellas
Cap'tAttack
144 attack
I went with a 1.5inch Crossover . I do approx 60 % off trail and 40 % on trail. It seems to make a noticable difference cross country in fields where the stock track failed miserably. On trail, adds just a little push into the corners but very manageable. Once i switched to the 144 inch I wasn't able to pull full rpm, It was down to just over 10,000. So went to a 23-39 gear ratio and rpm's are where they should be 10,600 to 10,800. I then tightend the limiter strap two holes and turned the transfer rod down to minimum. It will now lift skis approx 6 inches when it hooks up.
The greatest difference you'll notice is the fantastic ability of the sled to hook up now. Just hang on.
