207nytro said:
The main reason for me wanting the 144 over the 136 is that the sled must be able to keep up with a crossfire with a two inch paddle off trail. We aren't worried about being able to run high speeds down trails. I said 75/25 but that is for the moment. We would like to get into more offtrail riding somewhere around 50/50.
Well if the usage changes so does the answer.
1.75" tracks work great on and off trail. You don't really start to feel the vibration on trail till around 2" on most sleds. My 136"x1.75" runs smooth on the trail. If you want the off trail performance enough to stretch it out all the way to 144", going with a 1.5" seems like your stopping short. I agree with snownutz the backcountry would be a great choice they work well off trail and still run smooth on the trail.
I would say extros are a must if plan on spending 50% if your time in good snow. Without them you will have to run your track as tight as you can get it. For a 1.5" 1.75" track stick with the stock driver size, there is more then enough room to push snow thru and you won't give up efficiency that you would with smaller drivers. When you have the track/drivers out, remove all tunnel protectors.
As for clutching and gears that is a good, better, best thing. Will the stock gearing and clutching work? Yes. Will it work as well off trail as a sled that is geared down and properly clutched? Absolutely not. The more load you put on your sled in terms of snow depth and hills the more important gearing and clutching is. Going with a smaller top sprocket will cost you about $20 and can make a huge difference. I would suggest dropping at least one tooth on the top. Clutching is a thread on it's own but again it is the difference between working good and working great. ....you can also end up wrenching in the wrong direction with clutching
....also add some sort of tunnel block off to the shopping list. Ice build up can get crazy off trail. ....and all that weight= :exc:
Here is the cole's notes of my suggestions.....
Backcountry track
OFT 136" or 144" kit
Extro drivers
2 Extra wheels for slider wear
Remove tunnel protectors
Drop 1 or 2 teeth top sprocket
SBR kit or something similar
Block off plate
4th rear wheel
