Chris600
I have read a lot of threads in this forum I it seems like a very good improvement will be to swap to 151x2" track and move the skid 3" back.
If I do that do I need to change gearing? And to what gear in that case? It seems like we here in Europe has 41/19 gearing and USA has 41/17. So should I go for 41/17?
If I change gearing will the schmidtbrosmotorsports clutchkit stage II for MTX still work as planned?
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
Yeah that is the the correct gearing I have a ulcer clutch kit in mine but I am going to change it this summer and put my old weights in and just add weights.
If you ride anywhere close to sealevel you will not need to go to a 17tooth, stay with the 19, it will turn it fine. if u are at higher elevation you may want the 17. Sounds like the secondary helix from smidt Bros is pretty worth it.
Chris600
I am riding at about 1000feet upto 1800feet
