Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I agree. I went 160 Kms without holding it over 6000 for long periods. It was kinda tedious but, I could still get 80 mph. And I broke the sled in one day. 500 miles. Works great. Now that I lightend the clutch weights
bbquadrider
- Jan 22, 2014
20 full throttle runs ....broke in in 20 minutes
via big bad phone
via big bad phone
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Brapp
Via big bad viper joe
vibeline
- Dec 31, 2007
- 2016 ZR7000
80mph at 6000 RPM????I agree. I went 160 Kms without holding it over 6000 for long periods. It was kinda tedious but, I could still get 80 mph. And I broke the sled in one day. 500 miles. Works great. Now that I lightend the clutch weights
Wow you got a good one.
Mine only goes 83MPH @WOT on the trail
I should have bought a Yamaha
cheers
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
My sled has a trail turbo. I geared it taller then stock.80mph at 6000 RPM????
cheers
viperdude
- Jan 12, 2016
- Stratford Ont
- 2017 SW LTX SE
Hey Joe, i have the same sled as you with MPI trail and Ulmer clutch kit. Im only shifting at 8200 and not really happy so far. Comes out of the hole good but not pulling that hard. My weights are 3-0-3 and not sure what angle the ulmer helix is. Its a 137 with 1.25" and i only got 30 km on so far. Maybe i need to be more patient and get some km on before i try switching up clutching. What gearing did you go to and what is your clutching setup?My sled has a trail turbo. I geared it taller then stock.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I'm trying to tune my sled in too. I'm shifting at 8200 also. I can't get much more. Ulmer told me to lighten the weights so I did. I'm at 2-0-2. I also raised the belt in the secondary.Hey Joe, i have the same sled as you with MPI trail and Ulmer clutch kit. Im only shifting at 8200 and not really happy so far. Comes out of the hole good but not pulling that hard. My weights are 3-0-3 and not sure what angle the ulmer helix is. Its a 137 with 1.25" and i only got 30 km on so far. Maybe i need to be more patient and get some km on before i try switching up clutching. What gearing did you go to and what is your clutching setup?
Changing the weights didn't seem to do anything. At first I thought it did but at wot it's still strogling to see 8250.
I'm new to clutching , but I'd like to try something different.
Did you change your gearing?
viperdude
- Jan 12, 2016
- Stratford Ont
- 2017 SW LTX SE
My gearing is stock. I wonder if the Ulmer helix is a bit too steep till everything gets broke in better? Im going to lighten the weights up 2-0-2 see if i see a difference.
Do you have any gauges A/F, Boost?
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
Run it hard all through the rpm range just no sustained redline...also do not overheat.
This is how I did mine. I changed the fluids after 300 miles and run her anyway I want after that.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I ran gauges on my sled for the first 500 miles. Then my gauge broke. But it was all within spec.My gearing is stock. I wonder if the Ulmer helix is a bit too steep till everything gets broke in better? Im going to lighten the weights up 2-0-2 see if i see a difference.
