16" Renegade track on Warrior
alterhi
Michigan
Doo Renegade is running a 16/136/1.25 ..
They claim it is like running a 144.
Do I have to change anytrhing on my '05 Warrior to run a 16" 136 ?
What about a 1.5" ?
new drop down bracket,(3/16 thick)
new rearcross shaft or spacer (because bracket c/c of bracket will be different)
and grind a bit of a bolt on the chaincase and the nut inside. (lower one)
I have put 1/8 thick washer on each side of the upper shaft of the h-arm (rear suspension front hole), because tunnel was a little bit tight there.
Then you will have plenty of room to put the 16 inch. About 5/16th each side ;)!
i made all myself, i have made the drawing for the drop bracket and made by laser cutting. I do the rearcross shaft myself.
