So my 19xtx has wotn the front half of my carbides clean off at 1700 miles. No shims under the block from new. If i reverse the rubber block( rear is higher then front) to solve? If i must shim a)are shims designed to work on their mountain ski and b) where do i go in canada to get some and c) what sizes do i need. ?
you want the ski tips up naturally when you lift the sled by the a arms. you can try flipping the rubbers to achive this. i usually use a chunk of rubber mud flap from a transport to add to the rear to achive this on my sleds.
