I don't know why I posted that, but anyway, even if it has two shims it may need another thin shim added.Sometimes machines don't get updates done.
Joe williams
- Dec 22, 2020
- Wisconsin
- 09 Phaxer and 14 sr viper ltx
Ok finally go the belt in and that didn’t work. I am going to try the shims now. When putting the clutch back together. It appears A1 is stock. Do I have to turn the helix at all? Or as long as it is lined up with Hole A and hole 1 it is good?
Joe williams
- Dec 22, 2020
- Wisconsin
There is only one shim. I am adding another today.I don't know why I posted that, but anyway, even if it has two shims it may need another thin shim added.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
You'll have to rotate the moveable sheave to get the ramp on the helix past the plastic buttons (45 degrees if I recall correctly for A 1. Its been a while since I've put together a stock phazer clutch) before pushing the helix all the way down. I suggest using a new snap ring when re-assembling.
Joe williams
- Dec 22, 2020
- Wisconsin
You have me worried. I don’t have any plastic tabs and not sure how I could turn the helix. I can try and upload a video if that would help. Thanks!You'll have to rotate the moveable sheave to get the ramp on the helix past the plastic buttons (45 degrees if I recall correctly for A 1. Its been a while since I've put together a stock phazer clutch) before pushing the helix all the way down. I suggest using a new snap ring when re-assembling.
- Nov 1, 2009
- 2009 Phazer RTX
There are little plastic "buttons" that go in the moveable sheve next to the letters or numbers.
I had a video posted in the FAQ but it was hosted on photobucket and is no longer available. I've been unable to find the video as it was a while ago.
I don't have a stock phazer secondary clutch anymore to be able to take another video, my clutch is different now. Have a look through the FAQ for the post called "phazer secondary clutch assembly" there are also written instructions. Hopefully that helps. If you need clarification on anything don't hesitate to ask.
It has been a long time since I've opened a phazer secondary clutch, so I'm pretty rusty haha.
Joe williams
- Dec 22, 2020
- Wisconsin
Ok Thanks. I will look for the plastic buttons again. I have an 09. So I am wondering if they are no longer there. I have the spring in A1 and will rotate it 1/4 to 1/2 turn. Waiting for the new clip now.
Joe williams
- Dec 22, 2020
- Wisconsin
First thanks for all your help. I added another shim and the belt started screeching. Took the secondary back off remove the shim. Put it back together and same screeching. Am I not twisting the clutch enough when I am putting is back together?
Joe williams
- Dec 22, 2020
- Wisconsin
I was able to figure it out. I wasn’t twisting it enough before pushing the helix down. I twisted it a good 1/2 turn. Once I’d that everything is back together and running good.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
And reverse?
Joe williams
- Dec 22, 2020
- Wisconsin
So far so good. I tested it the other day and it was working fine. I update this thread after I get it out for a longer ride.And reverse?
Northern Viking
- Mar 11, 2021
- Sweden
- Sweden
- Multipurpose 2009
Back from your ride yet?So far so good. I tested it the other day and it was working fine. I update this thread after I get it out for a longer ride.
- 7K
