newfieattak
just picked up 2 inch 136 camoplast challenger and 9 tooth external doo drivers, and changing gear down to a 22 top on 07 attak ,any one else put a 2 inch on , is there enough room with tunnel protectors removed.
looks like lots of room at front of track not sure above clearance will allow with out going to 8 tooth drivers.
Turk
Tech Advisor
1.75 is about all you got!
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
I put 2" track on my rx should be the same as a attak,I used the stock 9 tooth drivers even with tunnel protectors in place.heres the link
http://ty4stroke.com/viewtopic.php?t=27128&highlight=
newfieattak
turk,have you put a 1.75 on , i can cut down the track.
Turk
Tech Advisor
I have personally seen a 2.25 cut down to about a 1.75 fit on a 07 Attak. Wicked hook!!!!
newfieattak
just wondering if i put a set of 8 tooth drivers on would it give me clearance for the 2 inch
Turk
Tech Advisor
8 tooth drivers will give you enuff clearence but you might have to change gearing cus 8 tooth drivers really lowers your gear ratio a lot.
newfieattak
this would give me a more mountain like gearing,
stronger out of the hole. ratio should be 1.84 instead of 1.73
I just in stalled a 1.5 track on my attak yesterday. I took out the tunnel protectors, there is lots of room.
newfieattak
just installed 2 inch today , have about 1/4 inch at front and no rubbing any where when ran on stand.
mclarenyamaha
have anybody tried these noslip weels. sombody says they are no good qualiti compared to whal-bros noslip. have sombody tried these on apex and how did they function. and is the diameter on the driveshaft the same.
newfieattak
put on doo extroverts very good quality same shaft dia as yamaha ,ran last year on apex rtx no problems
